Discussion topic: Broadband is not connecting
This message was authored by: Divorce67
Internet as been drooping in and out a lot .. now won't connect at all
Re: Broadband is not connecting
@Divorce67
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
