Discussion topic: Broadband down in Lancashire
This message was authored by: Lisawe
Is anyone else having Sky Broadband issues in Lancashire, or any other part of the UK? My connection suddenly dropped, and I can't seem to fix it.
Avatar for Lisawe
Level 0 icon
Re: Broadband down in Lancashire
  • It shows on the website that my router is connected, but non of my devices have a Internet when connected to my router.
@Lisawe
There are bound to be a small proportion of the UK population with broadband issues due to the high customer numbers.
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
