Discussion topic: Broadband is down
Message posted on 28 Jan 2025 08:39 PM
Broadband is down
Our broadband is down ever since the storm last Thursday night. Our electricity came back last night and our WiFi is totally gone and not working. Is anyone else having the same problem
Message posted on 28 Jan 2025 08:47 PM
Re: Broadband is down
@Paulafan
The wait for any necessary Openreach visit will still be delayed due to the disruption from the recent storms.
