Discussion topic: Broadband giving foreign IP address
Message posted on 10 Aug 2024 03:27 PM
Recently over the past couple of weeks my sky broadband thinks I'm in England when I'm actually based in Ireland.
Am I being given a UK ip address for some reason?
It is affected the content I stream, radio stations unavailable, being pushed to .co.uk instead of .ie websites etc.
How can I fix this?
And is there a way to stop it happening again?
Message posted on 10 Aug 2024 03:32 PM
Re: Broadband giving foreign IP address
Which hub do you have ?
Normally if you log unto your router interface and select maintenance. Then at the bottom of that page click connection status and click disconnect. Then after half an hour reconnect. You should now have a new ip address for the ROI
Message posted on 10 Aug 2024 04:16 PM
Hi
Thanks for the reply.
This didn't make any difference still connecting to UK.
I had previously turned everything off for a couple of hours too without success.
I have the sky broadband hub.
Message posted on 10 Aug 2024 04:24 PM
Use this but just copy and paste the asn number
Message posted on 10 Aug 2024 04:25 PM
Possibly Sky Broadband is doing an internal reallocation of IP address blocks: these need to be registered against a country for geolocation to work, and there's a lag time in doing so.
Message posted on 10 Aug 2024 04:38 PM
AS5607 Sky UK Limited
This seems to suggest I'm in Dublin (which I am) but multiple over IP address searches I've used say I'm in Doncaster Uk
Message posted on 10 Aug 2024 04:40 PM
Yup, defo uk. ,
Message posted on 10 Aug 2024 04:43 PM
Its the asn that stipulates your isp and country. Per @TimmyBGood its possible that uk has passed spare ipv4 numbers and the ripe database hasn't caught up
Message posted on 10 Aug 2024 04:49 PM
So just wait and it should catch up?
Is the disconnect via logging into the hub any different than plugging everything out at the wall?
Because I've done that multiple times recently and nothing has caught up
Message posted on 10 Aug 2024 04:58 PM
Best to call sky ireland but their lines aren't open over the weekend. Tried to find sky irelands asn to no avail. So yup you could try disconnecting the hub until it doesn't show 5607 even up here in couny down google geo location can be hit or miss but asn hasn't changed.
Message posted on 09 Sep 2024 09:16 AM
Message posted on 05 Nov 2024 11:54 AM
Has anyone had this problem resolved? It's ridiculous that this is still happening. We can't get RTE radio, all our search results show up as UK, shopping shows sterling prices. It's very frustrating.
Message posted on 08 Nov 2024 12:32 PM
any good news from users on this thread?
i am trying all possible ways but no luck.
so checking here for some hope if anyone got resolved permanently
Message posted on 19 Dec 2024 10:56 PM
My hole house has this problem its effecting everything in the house
Message posted on 20 Dec 2024 08:04 AM
@Brego given the issue is the public IP address Sky has assigned to your hub it will affect every device using that connection.The steps posted above usually work but not always instantly.
