1
This discussion topic has been answered Discussion topic: Broadband fluctuating
This message was authored by: Andy713
The WiFi signal in my flat is cons dropping in and out, I have done the speed test and it says that it's okay but the problem is still there any suggestions?
Re: Broadband fluctuating
@Andy713
See further down for guidance on the lights on the various hubs.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
@Andy713
