Discussion topic: Fibre
Message posted on 11 Jan 2026 01:31 PM
Fibre
Full Fibre down. ONT optical light solid red. Existing Sky FTTP over Netomnia. Need fault raised.
Message posted on 11 Jan 2026 01:50 PM
Re: Fibre
As your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them so they can look in to this for you.
Message posted on 11 Jan 2026 02:58 PM
Re: Fibre
@OD Are you ROI based?
Message posted on 11 Jan 2026 03:01 PM
Re: Fibre
No I'm in South Wales
Message posted on 11 Jan 2026 03:05 PM
Re: Fibre
@OD OK Did not know when you mentioned Netomnia as your Fibre connection thought they only supplied Virgin Media?
Message posted on 12 Jan 2026 01:57 PM
Re: Fibre
It was installed when I was with Youfibre.
Only last 3 days has this issue occurred.
Message posted on 12 Jan 2026 02:03 PM
Re: Fibre
@OD Your post is very confusing, sky use OR/CF Openreach or CityFibre for the connection, netomnia is a Altnet and sky does not use that in the slightest, are you using a sky Hub and waiting on a new connection from sky?
