Discussion topic: Broadband dropping out
This message was authored by: Susannah2603
Having problems with the Internet connection dropping out. Used the tool to check the Internet, but it says its OK. It's dropped out at least a dozen times today between 3 and 5.30pm today.
Re: Broadband dropping out
@Susannah2603
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
This message was authored by: DavidB4
I will second this. My connection has had poor stability recently. These checks aren't detecting any issues though.
This message was authored by: Hel896
Same here, connection has been very unstable recently and the service doesn't detect any issues...
This message was authored by: Jo273
Same again, all tests come back OK. I've reset the Huddersfield and it's not working.
Is there anything else I can do
