Discussion topic: Wifi
Message posted on 14 May 2025 10:11 PM
Wifi
I'm currently in my bedroom and I'm not picking up WiFi
Message posted on 14 May 2025 10:20 PM
Re: Wifi
My WiFi is also down but if I try to 'check the connection' Sky is telling me that there's nothing wrong with my WiFi. I think the fact I'm using my mobile data & my sky box won't connect to the internet says otherwise!
Message posted on 15 May 2025 05:06 AM
Re: Wifi
@StephBowman
Wi-Fi is the connection between devices and your hub. Broadband is the actual internet connection provided by the ISP (in this case Sky).
If you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
