Discussion topic: Broadband dropped out
This message was authored by: Erob45
Message posted on 22 Feb 2024 06:02 PM
Internet has dropped out and is struggling to reconnect
Find out more
Message posted on 22 Feb 2024 06:09 PM
Re: Broadband dropped out
@Erob45 Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
Message posted on 22 Feb 2024 06:17 PM
Thanks I have run the test . It says there is a problem with the broadband but when I click let's fix it ....it says everything is OK. Its clearly not 🙄
