Discussion topic: Broadband down
Message posted on 17 Oct 2025 02:58 AM
Broadband down
Message posted on 17 Oct 2025 03:16 AM
Re: Broadband down
Yip exactly the same here
Re: Broadband down
Message posted on 17 Oct 2025 04:02 AM
Re: Broadband down
Message posted on 17 Oct 2025 04:07 AM
Re: Broadband down
Mine also down
Message posted on 17 Oct 2025 06:03 AM
Re: Broadband down
When there are issues between midnight and 7am it's quite possibly going to be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep. Hopefully it'll be back before 7.
If it's not use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
