Discussion topic: No TV AGAIN, NO WIFI !!!
This message was authored by: Carolinejones
I'm not bery impressed this keeps happening, what am I.payomg for ?
Re: No TV AGAIN, NO WIFI !!!
@Carolinejones
l’m afraid you aren’t speaking to Sky Customer Services by posting on here. This is a customer ➡️ customer discussion forum where we try to help other Sky customers.
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
