Discussion topic: Broadband down
This message was authored by: Martobelli
Broadband down
Broadband band not working
This message was authored by: ChrisL2
No WiFi
WiFi has gone down, but Sky say there are no issues.
This message was authored by: D70
No WiFi
WIFi cut out and now I've got continous orange lights on the second and forth lights on the hub. Ran a test and according to that there was no problems with anything, even though I have no WiFi. Any suggestions why?
This message was authored by: Huseyin3225
Reset my broadband 5 times but still amber light
I reset my WiFi about 5 times but it's still jus showing an amber light even held it for over 10 seconds  and yes I checked all the cables are plugged in , it's jus showing an amber light on the internet
Re: Reset my broadband 5 times but still amber light
@Huseyin3225  First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Re: No WiFi
@D70  First thing to check is this link to see if there are any outages in your area:
This message was authored by: LR231
No internet light voice light orange
My internet was working fine until about an hour ago, when it just dropped out for no reason. and as I have sky glass this now means nothing is working.
I have reset the hub numerous times but nothing is working!
the voice light is orange and there is no light for internet.
Re: No internet light voice light orange
@LR231  At this time of night it may well be maintenance carried out by Openreach.
In such cases or where there's a fault resetting your hub is a pointless exercise.
Re: No WiFi
@ChrisL2  First thing to check is this link to see if there are any outages in your area:
Re: Broadband down
@Martobelli  First thing to check is this link to see if there are any outages in your area:
This message was authored by: SpreadTheWord
Re: No WiFi
Pure joke sky fibre.  Orange far right light on router.  Then just there home phone line pinged.  Now error on catch up Tv.  But this dumb app showing everything as working.
can't wait to leave these idiots.
Thanks for these but I already tried all of them with no luck! Still have no internet light and reset the router numerous times as that's all the troubleshooting is telling me to do.
everything says that the connection is fine with no faults so I don't know what is happening
This message was authored by: Pereira1
Same problem I'm having with the broadband
It's so annoying that the broadband checker says there's no issues when there clearly is if it's more than one person with the same issues!
Exactly
