Discussion topic: Broadband down
This message was authored by: ThomG
Broadband down
Hi - I've got no broadband; the tests say everything is OK but there's no actual Internet!
Tv service is unaffected but access to streaming apps is also gone.
Re: Broadband down
@ThomG
Have you tried running this line test:
This message was authored by: Rosh03
Re: Broadband down
Currently having the exact same issue
This message was authored by: Tristanandlaura
Re: Broadband down
As am I.  Restarted multiple times.  My mesh network connected to sky router is working but can't pick up any internet.  Suddenly went down hour or so ago.
Avatar for ThomG
Re: Broadband down
Hi - I've tried this several times but it gives rhe same response, thinks everything is fine.
To be specific: my PC and phone see the connection but there's nothing on it, connection is 0%.
Leamington Spa area.
This message was authored by: Thelostlibertin
Re: Broadband down
Yep currently having the same problem. Everything says it's fine. But there's no green Internet light on the router and the Internet is clearly down
This message was authored by: Aedam
Re: Broadband down
Same issue here in Essex. Fibre box on the wall all saying fine. No internet light. Reset both the fibre box and the router twice, same result. At all times sky automated checker says it's working fine. Did an objective test and unplugged the fibre box as well as the router then ran the test and it still says it's working!
Re: Broadband down
I'm also in Essex. Open reach lights are all green and there's nothing on the LOB light to indicate an external issue... Yet here we are!
This message was authored by: CjC13
Re: Broadband down
I'm glad it's not just me. Tests are basically all good, apart from I need to switch/activate my internet??
I've got green pulsing light.
This message was authored by: Nikkinoo143
Re: Broadband down
Mine has done the same are you back up yet?
N
Re: Broadband down
I'm in Essex also, does that mean the whole area is down 😱
N
Re: Broadband down
Nope, it's still having a nap.
Many restarts and unplugs.
Re: Broadband down
Voice light is orange, but I expect that with no internet.
LOB is clear on fibre, same as those of you above.
I guess it's a blip with sky's end and their system saying "this is fine guys honest" when it's not. Bug of some sort I suppose.
Re: Broadband down
FWIW this wrongly says everything is fine. I don't know what hub it's checking, but it's not mine!
This message was authored by: Bert3
Re: Broadband down
Same. Only been on Sky a day and a half, it's been down 4 times.
