Discussion topic: Broadband down
This message was authored by: KeeleyC
Broadband down
I have three green lights but it won't connect to anything. Switched off and reset, run tests and all seems fine. Is there an issue with anyone else?
This message was authored by: 1egohead
Re: Broadband down
Hello!
Try to check https://www.sky.com/help/servicestatus to see if there are any issues within your area 🙂
*Not sky employee*
Gigafast User | New to the forum | Tech Analyst | Jira Agile Amateur | Ubiquiti Network | Cyber Security Degree
Like if you found my reply useful 🙂
This message was authored by: lisa+russell
Re: Broadband down
I have been having to reboot my router every week since upgrading my broadband to full fibre. Ive been a sky customer for 22yrs had a new router installed about 4 months back everything was fine. Changed to full fibre 1 month ago & its awful. Shouldn't have to reboot each morning twice last week.
Avatar for KeeleyC
Re: Broadband down
Checked service status says no issues however it normally says that even when there is issues
Re: Broadband down
Sadly youre correct in saying that However if the issue has only started during the early AM's, they probably havent had time to update the webste yet.
Is the connection between the router and the box on the wall intact?
*Not sky employee*
Re: Broadband down
What aspect of your broadband isnt working? Is your connection working fine over ethernet?
*Not sky employee*
Avatar for KeeleyC
Re: Broadband down
Everything is connected how it should be. Really frustrating as I work from home
Re: Broadband down
@KeeleyC Sky and Openreach like all network operators have to maintain equipment which can result in connections being down from around midnight to 5am. This is unavoidable but can be incovenient.
Avatar for KeeleyC
Re: Broadband down
But it's 8am and it's still not working?
Re: Broadband down
Sky ended up sending an engineer out to check my equipment. I was told there is a known issue with full fibre. They will be rolling out fixes/updates oct/nov. In the mean time he put me an ethernet cable from my sky q box to the router. Apparently this should stop the Internet dropping like it has. Nope 1 week later & im still having to reset my router. I was told to unplug router & ethernet cable for 10 minutes. This will send a signal to sky showing your having problems. If not sky have no clue theres a problem. Oct/nov roll out for fix we shall wait & see.
