Discussion topic: Broadband down repeatably today in TR8
This message was authored by: MikeL4
Four times today the Openreach modem loses connection i.e. red light is showing on the openreach modem.  Despite numerous restarts it connects again after 30 to 45 mins, and yet the sky broadband checker on my phone (connected by 4G) is showing everything is OK.  Says "can connect to router" which I find hard to believe as there is a red light on the openreach modem and no internet light on the sky router.
Avatar for MikeL4
Re: Broadband down repeatably today in TR8
...and in addition this has been happening quite a lot in the last couple of weeks
@MikeL4
If your broadband isn’t working and you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
If you’re still having problems you may need to call Sky to report it. The easiest way is to dial 150 free from your Sky Talk landline if it’s still working.
For customers working from home please remember that Sky Broadband is a domestic service so you won’t receive any quicker or extra support.
Avatar for MikeL4
I attempted the servicechecker via my phone (as I had no broadband connection) and it repeatedly said all was OK (green ticks) despite the openreach modem having a red light, the sky router showing no internet connection light and the sky router status page showing as disconnected.  Did try to report it by calling but was on hold for so long that it ended up coming back up before I managed to talk to anyone.
