Discussion topic: Broadband down but sky help is rubbish
Message posted on 04 Dec 2025 09:31 AM
Router shows orange lights for internet and talk. I Do all the recommended steps to reset and then get a message from Sky to say Broadband is up and running and working well.
It definitely isn't, the Broadband and Talk status on the Router is still the same.
Why do they lie ?
How can I get this problem resolved?
( it's not the first time this has happened)
Message posted on 04 Dec 2025 09:34 AM
Re: Broadband down but sky help is rubbish
@DB106 First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Message posted on 04 Dec 2025 09:39 AM
Thanks, have checked both of the things you suggest. Sky say it's all good but it absolutely is not. It's so frustrating to be told that when I'm sitting here looking at the Orange lights
Message posted on 04 Dec 2025 09:46 AM
@DB106 If nothing is returned when the software test just does not get the answer especially if it is an AREA wide fault, takes a few hours to work it all out, call to sky and they may possibly know what is going on, does mean hanging on the phone though!
Message posted on 04 Dec 2025 09:56 AM
Thanks Jim, going to do that now.
This has happened previously, we had a 3 day outage when Sky initially said nothing was wrong and then agreed to look into it with BT. 3 days later it came back on without warning or apology.
To add insult to injury a week or two later we received a monthly monitoring report which said our internet service for the last 28 days had been 100%. Totally untrue 🤬🤬🤬🤬🤬
