Discussion topic: Broadband down again second time in two weeks
Message posted on 29 May 2025 07:56 AM
Broadband issues again LS26, second outage in less than two weeks last time was off for nearly two days and had to repair bothTV boxes was a nightmare. Reset modem numerous times and second light flashing amber.
Message posted on 29 May 2025 08:07 AM
Re: Broadband down again second time in two weeks
For a ‘no broadband’ issue, if you haven’t done it yet use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault perhaps affecting multiple households.
Message posted on 29 May 2025 08:11 AM
Yeah done all that thanks, have booked an engineer for tomorrow. Have had Sky broadband for 15 years plus and never had many issues but since Sky had their outage been down twice ! in lees than two weeks !
