1
This discussion topic has been answered Discussion topic: Broadband does not work
This message was authored by: LauraLuty
Our Broadband does not work. We need an engineer.
Re: Broadband does not work
@LauraLuty
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
@LauraLuty
