2
This discussion topic has been answered Discussion topic: WiFi down
This message was authored by: Ceej79
WiFi down
Re: WiFi down
@Ceej79 @Boglarka2
See further down for guidance on the lights on the various hubs.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
This message was authored by: Boglarka2
Re: WiFi down
Mine keeps dropping too.
Re: WiFi down
@Ceej79 @Boglarka2
