2
This discussion topic has been answered Discussion topic: Broadband disconnected
This message was authored by: Panos-Tsapralis
My broadband connection has been disconnected around 45 mins ago. Postcode: NW95 QQ.
This message was authored by: Doc5907 Answer
Re: Broadband disconnected
@Panos-Tsapralis
To begin with try checking if there are any outages in your area using following link.
If this shows no issues you could try running the line test at the following link.
Sky Q 1TB UHD
LG TV
Sky Mobile
@Panos-Tsapralis
Sky Q 1TB UHD
LG TV
Sky Mobile
Avatar for Panos-Tsapralis
Thank you very much for your reply. After going through all the steps & guidance, I confirmed there is a technical issue. I then called Sky on the phone - they, too, confirmed something is wrnog away from my home - they are arranging for Open-Reach engineers to fix it in the next 2-3 days (hopefully).
Thanks again,
