25 Jun 2022 10:00 PM
Recently upgraded to ultrafast broadband, and since then have had very varied speeds even though the sky app says that the connection is fine and that I'm receiving the correct speed. I've tried to reset the hub and also the Openreach fibre box, but neither have made a difference.
My Router stats are as follows:
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN WANoE 1291589 2991039 0 3774 10549 00:15:16 LAN Up 7265236 3491115 0 13050 0 29:47:52 WLAN (2.4 GHz) Up 2244695 178245 0 12460 0 29:46:10 WLAN (5 GHz) Up 27523188 5407644 0 0 29717 29:46:11
Any help would be appreciated.
25 Jun 2022 10:47 PM
You could try replacing the ethernet cable between the ONT and Sky router, and see whether that has an impact on reliability?
28 Jun 2022 12:49 PM
Posted by a Superuser, not a Sky employee. Find out moreHi @Gilo46
Can you post a speedtest result?
