07 Jun 2022 07:59 PM
The broadband box not working there is only 2 green lights and the internet is blank. It turns itself on and off it is currently off.
07 Jun 2022 08:17 PM
Posted by a Superuser, not a Sky employee. Find out more@Adenf Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
07 Jun 2022 09:09 PM
Hi, @Adenf.
Can you run the Broadband Test, this can be done either via the MySky App on mobile data or use this link. If it shows a fault you should be able to book an engineer via the app. Also, could you post your Router stats and a 24hr system log? This link explains how to do that https://helpforum.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/td-p/2855717#
Otherwise, to discuss your issue further it would be best to call sky on 150 from your landline or
zero three three three seven five nine one zero one eight from any other phone.
