Discussion topic: Broadband box playing up
Message posted on 13 Sep 2025 04:08 PM
The green lights are working on both power and WiFi but there is a continuous flashing amber light on internet and steady amber light on voice
Message posted on 13 Sep 2025 04:11 PM
Re: Broadband box playing up
We don't know which hub you have. The below link explains the lights on the various hubs https://www.sky.com/help/articles/hub-lights-explained-start
Message posted on 13 Sep 2025 04:12 PM
Can you run the service checker on your my sky app
If initially you get all green ticks click on your broadband speed and click on test your broadband inside he blue box
Message posted on 13 Sep 2025 04:20 PM
@Hannah172 wrote:The green lights are working on both power and WiFi but there is a continuous flashing amber light on internet and steady amber light on voice
I have this same issue. Nothing is connecting and none of the online guides are helping and no answer from the support number. Did yours get resolved?
Message posted on 13 Sep 2025 04:26 PM
When I do this it brings me to the service checker and then it asks us to contact them but the number doesn't work 😅
Message posted on 13 Sep 2025 04:29 PM
@EmiliaMD
These are the current methods for contacting Sky. (Depending on your reason for making contact some methods will be more appropriate than others) …
🟩 📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline. The forum doesn’t allow the display of other numbers.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: for any customer whose services are restricted due to a missed payment phone contact is unlikely to work.
🟩 online help via this link
🟩 Sky Assistant 💬 should also be available via
🟩 Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Note ~ ROI customers 🔹If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required. The Sky Ireland phone lines are closed at a weekend.
Message posted on
13 Sep 2025
09:55 PM
- last edited:
15 Sep 2025
12:41 PM
by
Nimbob
I had an issue recently and struggled to find a customer support phone number (I have no landline so dialing 150 is of no use).
After much searching I came across phone number but even then I had to navigate loads of options designed to fob you off to online support. I gave pretty random answers and finally got through to a real person. They quickly resolved my technical issue for me at the first attempt.
Good luck !
Message posted on 14 Sep 2025 01:25 PM
I managed to get through to them and they said our issue is to do with the connection. They can't check the line on weekends because Sky uses 3rd party services for the line so their backend team can only check Monday to Friday. I've only been with Sky for a few weeks but it's been a terrible service so far 😞 won't be able to work tomorrow as I work from home too and I spent €40 in credit trying to get through to their support team.
