6
This discussion topic has been answered Discussion topic: Broadband and router keep disconnecting
This message was authored by: Marge22
Please help , I just keep loosing connection,  it happens regularly but it always says everything is fine , here are my router stats.
TIA
This message was authored by: jamesn123 Answer
Re: Broadband and router keep disconnecting
Hi @Marge22
Firstly, thanks for posting your router stats right off the bat as hardly anyone does that and its pain having to ask everyone🤣
Your stats suggest you have not had any line drops so the issues you are seeing must be WiFi related. I do note that you are exclusively using WiFi as the LAN interface is showing 0 traffic.
For starters I would give your hub a reboot as it has been up for 20+ days, sometimes it needs this to find a better WiFi channel.
I am NOT a Sky Employee
Hi @Marge22
Avatar for Marge22
Oh thank u   not often I do something right 😂
OK I'll try that must of been 20 days since I last had no Internet or WiFi problems , it was worse then , it took days to get back on.
And according to new analysis by internet speed comparison site Broadband Genie my village has worst speed in country , doesn't help 🙄
Avatar for Marge22
OK hot new router and also hot Openreach out who said there had been a fault at some point but reset it now .
Unfortunately still not working , infact got so much worse , please help .
Avatar for Marge22
Got not hot 🙄
@Marge22
Can you please post a fresh set of router stats
Avatar for Marge22
Hi James thanks for reply.
Think we've cracked it , our Openreach master socket has a built in filter so we tried a micro filter and so far so good . It's been like this for months and no one said try this 🤔
It's got so bad after openreach worker came I couldn't watch most of sky channels.
Thanks again.
