Discussion topic: Broadband WiFi gone
This message was authored by: SatiD
Broadband WiFi gone
WiFi gone. Nothing connected but test not picking that up.
Re: Broadband WiFi gone
@SatiD
Wi-Fi and broadband are different. Wi-Fi is the wireless connection between your hub and your devices. Broadband is the internet connection provided by your Internet Service Provider (Sky).
If you have a broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
