Discussion topic: Set up
This message was authored by: Alit3
Set up
Just had my broad band set up got 1 mobile, tablet and tv on the the WiFi the main tv in the living room won't connect to the internet
Re: Set up
@Alit3 if you have a white Sky hub go into the hub's sdvanced settings in the My Sky app and change the WiFi security setting from WPA3-T to WPA2 which can help,as some TVs have an issue with the newer security stsndard.
