Discussion topic: Poor wifi signal - no fibre available through sky?
Message posted on 05 May 2026 10:19 AM
Having issues with WiFi signal and currently no fibre available through sky , even though neighbours have fibre through multiple companies, but I'm in contract so can't leave.
do boosters work with sky max package and what are the best ones
Message posted on 05 May 2026 10:29 AM
Re: Poor wifi signal - no fibre available through sky?
If you are in a contract with Sky you can upgrade to Fibre as this shouldn't stop you if it is available at your address.
If you have Broadband Max on your account then Sky will supply up to 3 pods that can help with signal issues as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Message posted on 05 May 2026 10:30 AM
@GH37 the best boisters for a Sky Mac hub arecthe matched pods Sky will providecas part ofvthe WiFi Max package. In general,do not mix different WIFi kit from different manufacturers as the units canninterfere.
Switching to fibre will not cure issues with poor WiFi in your home but Sky can only provide full fibre if you home has access to either the Openreach or City Fibre networks it is possible that your neighbours are using one of the other smaller networks Sky cannot use or simply your address was not passed for technical,reasons which does happen occasionally unfortunately.
Message posted on 05 May 2026 10:32 AM
I'm on super fast 35 package the sky max doesn't seem to be available
Message posted on 05 May 2026 11:48 AM
@GH37 check the My Sky app as WiFi Max isxan ad-on tomany broadbsnd package. See https://www.sky.com/help/articles/sky-wifi-max
