Discussion topic: Broadband Speed
Message posted on 22 Aug 2025 09:26 PM
Broadband Speed
Since last night my internet speed has been really slow, on wifi and wired connection. It's really frustrating, reset my router and such but nothing has helped it. Is there any news of Sky problems in Norfolk?
Message posted on 22 Aug 2025 09:39 PM
Re: Broadband Speed
The first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is of no help give Sky a call to report it to them.
Message posted on 22 Aug 2025 09:45 PM
Re: Broadband Speed
So I've done all that and the speed to my hub is poor? Any fix for that or would it be best to give sky a call?
Message posted on 23 Aug 2025 09:55 AM
Re: Broadband Speed
@XsiegeX if the speed test in the My Sky service checker shows an issue the app should offer help. However if that is normal then the issue is likely to be slow WiFi in your home. Sky will sell you an add-on called WiFi Max which can supply WiFi extenders.
Hiwever there can be an issue with partial fibre lines where tge line has slowed but not to below the guaranteed speed for your line - you can see figure this by clicking beside the most recent test result. The issue here is Openreach are unwilling to take action rather relying on the autimatic systems managing the line to optimise the connection so Sky are essentially powerless.
