Discussion topic: Showing Vodafone still on wifi
Message posted on 23 Aug 2025 10:04 AM
I switched to sky from Vodafone. Didn't get a new hub from sky as they said my Vodafone hub was compatable. Went live on 22nd August and received a message from Vodafone confirming cut off date but wi fi connection on my devices still saying Vodafone ??? Sky app says I am connected to them
Message posted on 23 Aug 2025 10:08 AM - last edited: 23 Aug 2025 10:36 AM
Re: Showing Vodafone still on wifi
Unless you actually change the SSID of the wifi channels on the Vodaphone Hub then it will still show a Vodaphone SSID, it won't change simply bacause your connecting to another providers service.
If you wish to change it you'll need to go into the hub settings, however as it's not a Sky supplied hub you'll need to google the instructions.
I do find it odd that Sky have not sent you their hub as they tend to like people to use their hardware especially when running any fault finding.
Message posted on 23 Aug 2025 10:38 AM
@ddsam71 Very very strange, unless there is a problem currently getting a sky Hub out to you stock issue's etc could cause such, but be very careful with any changes you make to the Voda hub and DO NOT factory reset it what every you do!
