Discussion topic: Broadband Speed in Islington London
Message posted on 01 Apr 2024 11:31 AM
Hi there,
I've had speeds between 20mbs and 45mbps in N1 for the last 24 hours. (all devices + checks with ethernet straight into router, all resets and checks done)
Just wondering if anyone else is having trouble? No issues logged on the web site but it doesn't appear to be an issue in the flat
Message posted on 01 Apr 2024 12:20 PM
Re: Broadband Speed in Islington London
@mstrkrft run the connection test in the My Sky app to see if it reports an issue. You can check the speed your hub connects at by looking at your hubs stats see Find your Sky Broadband router statistics.Post them if you need help in understanding what they tell you.
