Discussion topic: WiFi not working
This message was authored by: EleW8
WiFi not working
Last three days my internet has not worked. I've used my sky app WiFi test and everything green. But the hub itself show yellow leds and internet flashing yellow , and it keeps disconnecting every few minutes
Re: WiFi not working
@EleW8 have you tried rebooting you hub by turning it off at the plug for 30 deconds then turn it back on again
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: BramJohnston
I'm having similar issues and find if you reset it by unplugging for 10+ seconds it might come back. It's no guarantee and a temp fix at most but better than nothing while you wait for a pro
