Discussion topic: Broadband Conversion Kit
This message was authored by: Boomer-69
Message posted on 14 Jan 2026 02:24 PM
My Broadband Conversion kit only comprised of a cable is that correct or should there be other items included?
Message posted on 14 Jan 2026 02:48 PM
Re: Broadband Conversion Kit
@Boomer-69 FF Full Fibre upgrade and you already have the sky Broadband Hub then the cable is it, see link below if you are not sure off the sky hubs! Cable used to connect the Hub port 4 WAN to the ONT, Longer one required then get what you need for yourself, especially if you need to keep the sky Hub central location when working well!
