Discussion topic: Sky. Glass
This message was authored by: Hollie993
Sky. Glass
Since getting sky glass I've had issues with WiFi connecting
everyday atleast twice the tv reboots or says there's a technical fault
I do all the checks with the WiFi hub and all seems fine and if it's not then I follow instructions to make sure that it's done correctly
anyone else's sky glass like this. My hub and tv are not far apart either
Re: Sky. Glass
@Hollie993 Are the TV and the sky Hub connected with an Ethernet cable?
Re: Sky. Glass
@Hollie993 go into the settings on the TV and look at the network tab which will tell you the quality of hhe WiFi connection - the hub maybe close but what lies between the hub and TV will have lot to do with how much TV signal the set gets..
Avatar for Hollie993
Re: Sky. Glass
Yeah everything seems good and connection shows good
