3
This discussion topic has been answered Discussion topic: WiFi down
This message was authored by: Kat0_1
WiFi down
WiFi has gone down for the 2nd time in 1 hour
Re: WiFi down
@Kat0_1
See further down for guidance on the lights on the various hubs.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
Re: WiFi down
@Kat0_1
This message was authored by: MichelleJ81
Re: WiFi down
Mine has just gone off too and I work from home! 😡
Re: WiFi down
@MichelleJ81 Same for all on the above link applies also for you from @Daniel0210 !
