Discussion topic: BroadBand down Kildare Town
This message was authored by: Clclcl
What is going on and when Will it be restarted?
Re: BroadBand down Kildare Town
@Clclcl
Is it just your connection that is down or are you aware of others in your street having problems too?
Have you check your areas status on the Sky Status page https://www.sky.com/help/servicestatus
I am NOT a Sky Employee
Avatar for Clclcl
Neighbours are down too
@Clclcl
Check the status page. If an area is fault is showing then there is nothing you can do to speed it up. If nothing is showing for you then I'd recommend you call Sky to make sure they are aware of it.
Avatar for Clclcl
And what's the point if this place?you just do nothing and dump the problem back on me?
@Clclcl
This is a customer to customer based forum you are speaking to fellow customers, not Sky. The community offers help on various topics but when it comes to physical broadband area faults we cannot do anything for you.
Like I said, if the fault is showing on your Sky Status checker then you can only wait for the problem to be fixed by Openreach. If it isn't showing I'd call and report it ASAP.
Also next time it would be nice if you posted without the attitude, members here post on their free time we are not paid or employed by Sky.
@Clclcl
It's always worth you making Sky are aware of such outages so you can possibly get auto compensation. The below link explains the Ofcom agreed auto compensation scheme which Sky operates for when there is a TOTAL loss of Sky Broadband or Sky Talk.
https://www.sky.com/help/articles/auto-compensation
If you have a total loss of service and it isn’t fixed after two full WORKING days from when you first report the fault to Sky, you will become eligible for it. It’s applied 30 days after the fault has been repaired and will come in the form of a credit appearing on your Sky account.
This message was authored by: Tem3
I'm also in Kildare town, briadband has been down since this morning, when I rang the customer care line earlier, they said it would be back up and running by 17:00
This message was authored by: Bd2
Has anyone got any updates from Sky on this, we're still down.
@Bd2
You won't get an update from Sky through this forum: realistically area outages are treated as a priority but still take as long as they take to resolve.  I believe that Open Eir has the same working target as Openreach for a two working days fix on individual domestic contracts, but an issue affecting more than one address will get more resources.
This message was authored by: Bubbie
No broadband connection
I have had no broadband since this evening. I have tried to reboot but no joy. Is there any other technical broadband issue overall??
This message was authored by: Michaeld2
WiFi but no internet connection
Router is showing solid green light for WiFi but no internet connection (solid amber) all day  since early morning, in Sallins, Kildare ! Help!
@Michaeld2
I moved your post here for visibility
Re: No broadband connection
@Bubbie  Are you around of near to Kildare town?
I live in newbridge
