Discussion topic: Broad band connection disconnecting
This message was authored by Choori This message was authored by: Choori
Issue with broadband connection keep disconnecting
Re: Broad band connection disconnecting
@Choori Can you please run the broadband test, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
Choori
It's look like don't work now asking me to try again later it's been ages now same  response
@Choori I have escalated your post to Sky who may be in touch with you regarding this via a private message on this forum or an email to you, both of which will invite you to a private chat.
More information can be found in the link below.
https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Choori
I think I'll disconnect the connection
This message was authored by Lisa-P1987 This message was authored by: Lisa-P1987
Posted by a Sky employee
Thank you for escalating this. We have now sent an invite to chat 🙂
Lisa - Sky Tech Team Expert
This message was authored by Mr+Flibbles+86 This message was authored by: Mr+Flibbles+86
Update – We are still looking to help you. If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
This message was authored by Abderrahmane+akou This message was authored by: Abderrahmane+akou
My broadband is not working
