Discussion topic: Blue pine power cable
This message was authored by Em19 This message was authored by: Em19
My rabbit has chewed through the blue pin power cable for our sky q box. Do I have to contact sky to replace it? Iv looked online and can't fine one
Re: Blue pine power cable
Hi @Em19
The power cable is a normal figure of 8 (C7) cable.
Readily available
https://www.amazon.co.uk/Figure-8-Cable/s?k=Figure+8+Cable
Em19
@oldfella
Hi @Em19
What Sky box is that for :
Em19
@oldfella it's a sky q box
Em19
@oldfella I have found this online but it has 3 options for ordering usp power, USB power or psu premium 🙈 I haven't a clue?
Em19
@oldfella
Found what online @Em19 ?
Exactly what Sky Q box is it?
This message was authored by Doc5907 This message was authored by: Doc5907
@Em19  hope the bunny is okay...
If you search ebay for 'sky q power cable', loads will come up for less than a tenner.
Sky Q 1TB UHD
LG TV
Sky Mobile
BT Broadband
Em19
@oldfella this is what I found online.
Em19
@Doc5907 he's fine luckily. Online all I can find are the figure of 8 ones but ours is a pin
@Em19 wrote:
@oldfella
@Em19  none of them will work.
Sky Q 1TB UHD
LG TV
Sky Mobile
BT Broadband
Hi @Em19
Becoming a bit clearer .
I suspect it is for a 3rd party Broadband router and not for a Q box.
Em19
@oldfella yes sorry it does go into the back of the broadband box not the sky q box 🙈 would the cable from myvolt work?
No idea @Em19
You would need to check the Power Supply voltage and current to make sure that it is identical to your damaged one.
Also the power pin must be the same size and polarity.
Power pins can be wired different .
Have you asked your Broadband supplier if they can supply a power lead or even a new router complete?
