Discussion topic: Blue light on wifi hub. No Internet connection
This message was authored by: Wills62
WiFi has gone off but you online checker says everything is OK
Re: Blue light on wifi hub. No Internet connection
@Wills62
Any engineer visit that’s required is likely to be delayed due to the disruption from the recent storms.
For any customers working from home remember that Sky Broadband is a domestic service so you don’t receive any extra or quicker support.
