17 Nov 2022 09:42 AM
Hi folks,
Have had supefast broadband for around 18 months, never been impressed, but usually ok when it comes to working and general browsing.
Downloading anything on Sky, however, seems to be ridiculously slow. I've also just upgraded to the UHD package, so i'm concerned that streaming / downloading anything in UHD is going to be difficult. I actually cancelled my broadband yesterday, as I was hoping to get faster speeds elsewhere. The person on the cancellation line, actually told me that the issue was with Openreach, and unless I went with Virgin (Not available in my area) I wouldn't get faster speeds with any other provider, on any other package.
Does the above sound right? And if so, am I better off getting the cheapest broadband deal possible, as 6mb (roughly) is the max I will get anyway?
Thanks in advance, any help would be appreciated!
17 Nov 2022 10:31 AM - last edited: 17 Nov 2022 10:54 AM
Posted by a Superuser, not a Sky employee. Find out moreThere's clearly a problem somewhere because your outbound speed is higher than inbound, and that should never be the case with FTTC*. To resolve such issues the customer logs a fault with their ISP, and the ISP then books Openreach to investigate.
*Working FTTC is asymmetric about 4:1 inbound: outbound
17 Nov 2022 10:34 AM
If sky say there is an issue with openreach did they not book an engineer for you?
Can you run tests from you my sky app and post the info in "more about your connection"
And enter your full postal address below and post the table after removing your address from the image
17 Nov 2022 10:47 AM
Thanks for taking a look @cookiemonsteruk.
No engineer booked, advised that there was nothing that a Sky engineer could help with, purely an Openreach issue. Definitely doesn't stack up.. screenshot below if that helps?
Thanks again.
17 Nov 2022 10:48 AM
Thanks @TimmyBGood, that makes sense.
The guy on the phone never mentioned booking an Openreach engineer to investigate, just that someone from Sky wouldn't be able to make a difference!
17 Nov 2022 10:52 AM
With a line that appears to be able to handle 75Mbps they should be contacting openreach to send an engineer not their own engineers. What exactly did they say was the issue. You need to contact sky again or we can escalate
17 Nov 2022 10:58 AM
No mention of them being able to request an Openreach engineer, although this was when talking to the cancelation team for broadband, not sure if their "tech support" team would have made that suggestion?
Very vague on the actual issue, just stating that the Openreach "setup/network" in my are would not be able to support download speeds any higher than a range of 4mbps-7mbps.
I think i'm hearing that a call into the "tech" team is probably warranted, to maybe get a fix before potentially renewing? If the issue can be fixed that is..
Thanks agan.
17 Nov 2022 11:04 AM
To save you the hassle of contacting sky I've escalated your post via the community chat. This link explains how it works
Keep logged on to the forum using a chrome browser
Keep an eye out for an invite or blue chat bubble. When the blue bubble does appear you have 48 hours to respond or it will be automatically closed.
17 Nov 2022 11:05 AM
Posted by a Sky employeeHi there, I have escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Just look out for the blue bubble to start the conversation.
17 Nov 2022 11:06 AM
Beat ya to it 😁👍
17 Nov 2022 11:16 AM
Thanks @cookiemonsteruk, that's very helpful, appreciate your advice / comments 🙂
17 Nov 2022 11:17 AM
Thanks @Addie15 :)!
17 Nov 2022 12:16 PM
Posted by a Superuser, not a Sky employee. Find out moreWow the Sky agent you spoke to must have not even looked at your routers line stats, thats one of the worst faults I've seen for a while how did they not pick that up?
17 Nov 2022 12:39 PM
Posted by a Sky employeeUpdate-We have booked an engineer for AFGrant23's problem to be fully resolved, we consider this closed on our end. If there is anything else we can help with, please do not hesitate to reach out. Thanks.
17 Nov 2022 02:19 PM
I'm not sure if that's reassuring or not 😂 at least I've got a bit of weight behind my concern now!
