Discussion topic: Bandwidth Feb 16th
This message was authored by: Standard654
Bandwidth Feb 16th
"Insufficient bandwidth" message trying to play a short video on BBC website.
Frequent timing out on Google searches.
Generally slow loading on all sites I try to connect to.
Sky diagnostic tests say all is ok. No known issues in my area.
Don't know what else to try.
Re: Bandwidth Feb 16th
@Standard654 that error message simply means that the connection to that devicecisnt fast enough to stream the video. If the device is connected to the hub by wifi it is almost certainly that the device is too far from the hub. Given wifi signal levels are affected by the layout and how your home is built its not unusual for a single wifi hub to be able to give usable wifi in every room.
