Discussion topic: Bad wifi
This message was authored by: Dean133
Bad wifi
We have had sky for a while now and I ain't impressed
the wifi is absolutely rubbish
the tv keeps pausing then the screen hoses blank and the sky box restarts
Re: Bad wifi
@Dean133 What box restart's by itself!
Avatar for Dean133
Re: Bad wifi
The tv box
Re: Bad wifi
@Dean133 Have you looked on the TV part of the Forum!
Avatar for Dean133
Re: Bad wifi
No not yet
but the wifi is awful upstairs in every bedroom
the router is at the bottom of our stairs so should be gd upstairs
beginning to wish I'd never gone with sky now
Re: Bad wifi
@Dean133 What hub are you using from sky! See the link below!
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
Avatar for Dean133
Re: Bad wifi
The sky max hub
Re: Bad wifi
@Dean133 Cannot say as never used, sky Max hub get's a very bad rap for the wireless signal strength. You need better and have the addon that goes with the hub as additional cost then details are below.
getting sky max and how to get the pod's
https://www.sky.com/help/articles/sky-wifi-booster-what-do-you-need-help-with
https://www.sky.com/help/articles/enhanced-wall-to-wall-wifi-guarantee
