Discussion topic: Trying to FTP via Sky Max hub - but cant connect
Message posted on 18 Jun 2025 06:35 PM
Shield is off but i cant upload where i have had no issues before
The Windows Firewall is off
Everything worked when i had VirginMedia broadband but Sky wont let me connect
Any ideas
Message posted on 18 Jun 2025 06:36 PM
Re: Trying to FTP via Sky Max hub - but cant connect
I cant even log into my Hub - everything says that the password for the hub should be on a sticker on the hub but i have checked over everywhere on the hub and there is no admin password
is there a Default?
Message posted on 18 Jun 2025 06:40 PM
@JaneCas65 Yes, it's all via your phone and the mobile app that YOU are required to use. Admin password is the wi-fi password bottom label on the hub!
Message posted on 18 Jun 2025 07:03 PM
Nothing in the Hub that shows any blocked ports
Broadband shield is off
but i still cant use FTP to upload files
Never had trouble before moving to Sky
Message posted on 18 Jun 2025 07:08 PM - last edited: 18 Jun 2025 07:11 PM
If the destination server permits it, try using SFTP (which is generally preferable anyway)
Message posted on 18 Jun 2025 07:13 PM - last edited: 18 Jun 2025 07:42 PM
Also see this thread:
https://helpforum.sky.com/t5/Broadband/FTP-not-working-after-upgrade-to-sky-max/m-p/4839939#M445308
In particular, it would seem appropriate to move from 8:1 to 1:1 Map-T
