Discussion topic: Bad connection
Message posted on 07 Feb 2026 11:51 AM
Bad connection
The connection upstairs in the house is very bad. Games constantly crash and run slowly
Message posted on 07 Feb 2026 12:00 PM
Re: Bad connection
@Kellymhew Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
