Discussion topic: Open reach modem no lights
Message posted on 07 Feb 2026 09:50 AM
Message posted on 07 Feb 2026 09:56 AM
Re: Open reach modem no lights
@Nick--88 if other devices work using the dame power outlet it sounds like the unit has failed. To get it replaced either run the service checker in the My Sky app over a mobile connection but note it takes up to an hour to pick up the lost connection. Thst can book an engineer to sort the issue or call Sky.
Typically it takes 2 full working days to get an appointment.
Message posted on 07 Feb 2026 10:53 AM
Thanks Chris, that is helpful. I've run the test in the app and it says their service network team will do some sort of check within 72 hours, so sounds like it may be a long process!
Message posted on 07 Feb 2026 12:01 PM
@Nick--88 standard service level for domestic lines is two full working days from report which Openreach keep to for 85% of issues.
Message posted on 07 Feb 2026 12:02 PM
Thanks, also should have called you Chrisee not Chris!
