2
This discussion topic has been answered Discussion topic: Authentication Problem
This message was authored by: heidilouise76
Hi
I can't connect my brand new Google Pixel phone to my wifi, I've typed the password in several times and keep getting the message 'authenticaton problem'. I've tried unplugging the router etc. twice but it's made no difference.
I've tried disconnecting (and forgetting) the network from other devices and have had no problem reconnecting everything again using the password.
Any suggestions would be very gratefully received!
Avatar for heidilouise76
This message was authored by: heidilouise76 Answer
Re: Authentication Problem
Hi @jamesn123
Thanks for your response, turns out it may have been the phone (it wouldn't connect to any wifi anywhere) so it's gone back and I'm waiting for a replacement, if the new one has the same problem I'll be back!
Thanks again,
Heidi
Hi @heidilouise76
Which Sky router do you have?
Are you sure you are typing the password correctly using the correct case, numbers & symbols?
I am NOT a Sky Employee
Hi @jamesn123
Thanks again,
Heidi
