Discussion topic: Asus Rx 58u
Message posted on 11 Jun 2024 11:32 AM
Asus Rx 58u
Morning all
after years of poor performance from my sky hub re wifi ive finially took the plunge and swopped it for a new asus Rt 58u.
Thanks to everyone who has given me advice re the subject.
i can report that its made the workd of differance no more drop outs i now have a steady reliable wifi and internet connection.
sky q works a treat as well.
Having said all that i still have a dead zone in my far room which is at the opposite end of the house to where my new router is positioned.
although my sky q box is in this room its connected perfectly its just things like iphone computers that struggle to connect.
so im going to hard wire a second asus router into that location and use it as a access point or aimesh.
Would I be ok using another Asus Rt 58u in ap/ repeater mode or would I be better off with say a asus Rt ax 86u maybe as the main router and use the Rt 58u as the ap/ repeater
any advice would be appreciated.
im on sky fttp
regards
Nigel
Message posted on 11 Jun 2024 11:47 AM
Re: Asus Rx 58u
2x RT 58u's should work fine
Message posted on 13 Jun 2024 05:44 AM
Re: Asus Rx 58u
Thanks agsin 👍🏼
Message posted on 13 Jun 2024 06:56 PM
Re: Asus Rx 58u
Just another question re using a second Asus
as a ap / Aimesh node.
does the second asus need to have the same option 61 set as per the main asus router.
im on sky FTTP using sky q
thanks again
Message posted on 14 Jun 2024 08:33 AM
Re: Asus Rx 58u
@Cheshireprowler Connect your 2nd asus WAN connection to the 1st asus on its lan. Use the asus web interface and set the 2nd asus for Asus Mesh control, it will sort out what is required for all of its settings, if auto FW is also on it will upgrade to it also.
Message posted on 14 Jun 2024 08:58 AM - last edited: 14 Jun 2024 09:09 AM
Re: Asus Rx 58u
No: that option only applies to the WAN port of the device connected to the ONT and doing the internet routing
(Wide Area Network: external internet connection)
Message posted on 14 Jun 2024 09:05 AM
Re: Asus Rx 58u
Thanks guys you've been so helpful
regards
Nigel
