Discussion topic: Asus 4 Wifi Mesh with SR213 Sky Fibre Router
Message posted on 11 Oct 2024 07:52 AM
Hello
I have installed a Sky Fibre Connection and the WAN port has the Fibre cable connected.
I have a WIFI mesh ASUS and I am not able to connect it to it as it does not connect from a LAN port.
Can someone please help me with the settings I need to change on the Broadband Box and on the Asus Router.
Kind regards
Message posted on 11 Oct 2024 08:10 AM
Re: Asus 4 Wifi Mesh with SR213 Sky Fibre Router
There are excellent instructions on the Asus site for performing the task:-
https://www.asus.com/uk/support/faq/1015009/ The units all need to be placed into access point mode, and a wire connection from one of the units needs to be from the WAN port to the Sky router LAN port.
Message posted on 11 Oct 2024 01:16 PM
Thanks Mae. It just did not connect and then realised that the device got bricked!
Any view on TPlink Deco P9 and compatibility?
Message posted on 11 Oct 2024 01:59 PM
Any views from anyone on Deco P9
Message posted on 11 Oct 2024 05:51 PM
@MR70 not sure how you bricked the Asus units. The Deco units are quite similar and are set up with an app just select the Access Point mode as explained here https://www.tp-link.com/uk/support/faq/1842/
