4
This discussion topic has been answered Discussion topic: Are Sky using auto VPN on my line?
This message was authored by: Robin222
Apple Support asked me to contact Sky and try to establish if Sky are using, or experimenting with auto VPN on my line?
Across several different sites I randomly receive messages saying my access to the site is restricted due to suspicious activity and flooding their sites. Solving a Capcha or exit browser and try again usually sorts the problem.
Apple support have looked deeply into this and say it has all the hallmarks of VPN problems, but I don't use VPN. Do Sky?
Re: Are Sky using auto VPN on my line?
@Robin222  Why would a large ISP with a full DNS set up use a VPN? Certainly  nothing to suggest Sky are experimenting and I think Apple support are stuck for an answer.
However Sky use MAP-T to share IP4 addresses between 8 customers on the white Sky hubs which has been in place for a year which could be the issue if someone using the same address has been naughty. Powering down your hub for an hour should force a change in IP address.
Avatar for Robin222
There are broadband companies in the US now who provide auto VPN to their customers.
Thanks for the tip resetting IP, sounds like a tremendous possibility, fingers crossed I'll let you know 🙏
UK internet regulation requires ISPs to have website blocking by default, and VPN provision would completely undermine this.
Avatar for Robin222
thank you so much @Chrisee so far no reoccurrence of the problem. i'll screenshot your reply to Apple Support
thanks again 🙏🙏🙏
