25
This discussion topic has been answered Discussion topic: Anyone else have issues with wifi
Avatar for Sassysteph
This message was authored by: Sassysteph
Re: Anyone else have issues with wifi
Asked me to press wps for 30 seconds still no WiFi working though
That's a Hub reset: it cannot resolve an external issue.
@Sassysteph Take it you have a sky Max white hub, what a waste off time that is for a full factory reset requested on the sky Agent side.
But they do have some procedure to follow even though not the best at times!
Yeah the white one they are sending me a new hub apparently the signal isn't connecting to the hub
@Sassysteph Smoke and mirrors would appear to be the outcome, at least you have a new one on the way, just hope it all goes well!
This message was authored by: Pedro+Leer
Re: Random disconnect
Same here [removed]
Moderator Actions: removed inappropriate language
This message was authored by: K809
NO Broadband
No sky internet, flashing green. Tried to restart and nothing! Birmingham area
Re: NO Broadband
@K809
This explains the lights on the hubs:
This message was authored by: kdsouthall
Re: NO Broadband
ive done the same with same outcome, done a broadband & WIFI check all coming back ok, but obviously not.
Re: NO Broadband
I have tried this all was fine and then just gone off. Flashing slow green and nothing coming back on
Re: NO Broadband
@kdsouthall @K809
Answered - Go to Answer
