25
This discussion topic has been answered Discussion topic: Anyone else have issues with wifi
This message was authored by: Sassysteph
Checked my sky connection says all fine have service can't get onto my WiFi on my phone on the glass tv anyone else having issues with broadband today
Re: Anyone else have issues with wifi
@Sassysteph
Try rebooting your broadband hub at the mains, if this doesn't fix it then give this a try:
Try running this line test to see if it finds any faults:
This message was authored by: Pake26
Yes I've a red light on my router but according to sky all is working fine!
@Sassysteph
Avatar for Sassysteph
Mines white but still saying connection is good can't get through on the phone either they just keep sending me a message saying check your service
 says it's fine but when I connect to WiFi it comes up with this
@Sassysteph So you are aware, pictures you post have to be approved and cleared for general viewing, until then no one see's it. Will take a look later, suspect you have a wireless wifi connection but NO Internet. Bars and the ! exclamation mark even though you have a white connected sky hub light!
Your picture has cleared and as suspected......
@Pake26 See below for you!
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby if enough time has passed for a fault condition to be displayed by the software test! This should determine if there's an identified fault affecting multiple households.
@Sassysteph
And what happens after you rebooted your broadband hub at the mains ?
@JimM1
The image should be viewable now.
@caesarome Thanks seen and replied.👍
This message was authored by: Scootbog
Having the same issue for last few hours. SKY app says all good despite a grey circle icon. No WiFi of Ethernet. Run diagnostics and it says all is good. Going round in circles trying to get through to sky.
@Scootbog
This applies to you as well:
@caesarome wrote:
@Sassysteph
I'm on chat now to sky finally
lol, done all that before posting. Still the same situation. No WiFi or Ethernet but white light on router and app saying everything is good
What was their response?
@Scootbog Was it not like your's switch the hub off for a couple hours?
